VimyJ wrote:This post has been on my mind but I haven't had the time to respond since reading it. The TPS has to be exactly adjusted or it will really screw with the transmission's performance. Spec's are .4-.5 volts. My testor isn't sensitive enough to detect that subtle a difference so I just incrementally adjusted it until it got "normal" again. Mine is still not quite right but it's almost there. The TPS can do all that you mentioned and mess with the way the TC locks and unlocks. Moving the TPS in fractions of a mm affect the way the transmission functions. Check it out before you do anything else.
I should have made mention that my method for adjustment involved carrying a Phillips head screwdriver in the J and adjusting the TPS every few miles of combined city/highway driving. I aimed at recreating the feel of the first to second gear change and proper function of the TC. It was interesting to note that at one point I had what I thought was the right setting but I couldn't keep the TC from switching off rapidly especially upon decelleration. However, when I switched the cruise on the TC behaved normally. This must be related to Q45tech's post about throttle effiency vis a vis manual vs CC fuel effiency. The OEM specification of .4-.5 volts is crucial. At this point in my adjusting, the last tinkering with the TPS mounting screws amounted to tapping once on the frontmost part of the switch once with the butt end of the screwdriver. Even this tiniest of adjustments resulted in a different response from the transmission. Wish I had never f##ked with this thing in the first place!:mad:
