95 J30 has lethargic pickup with slight hesitation w/ accelerating. idles smooth
coupedncal
Any idea how to replace O2 sensors and clean out MAF? I have a 95 J30 that has smooth idle but has lethargic acceleration. Mileage has also dropped recently from 21-22 mpg to 17-18 mpg. Again, idle is smooth but i feel slight misses in the engine when accelerating. Car has 207k with original O2 sensors.
gr8scott72
Car: 1994 Infiniti J30t
coupedncal wrote:Any idea how to replace O2 sensors and clean out MAF? I have a 95 J30 that has smooth idle but has lethargic acceleration. Mileage has also dropped recently from 21-22 mpg to 17-18 mpg. Again, idle is smooth but i feel slight misses in the engine when accelerating. Car has 207k with original O2 sensors.
It might be time to replace O2 sensors but if you're feeling a miss, that's not the O2 sensor, that is more than likely a plug/coil type problem.
brandonjustice93J30
Car: 1993 Infiniti J30
When was the last time the plugs were changed?
GerryO
Car: 1993 J30t
Pearl White
Black Interior
Based on an experience with a dirty MAF in my '97 Ford F-150, cleaning your's is a good idea. There are links out there to do-it yourself MAF cleaning instructions.
In my case a dirty one caused intermittent and very subtle missing/stumbles near the shift points under light acceleration, plus some intermittent and pretty violent jerking at freeway speeds in the 65 to 75 mph range. At first the problem occurred very infrequently and was barely noticeable, before it slowly got progressively worse.
It took about four trips to a local Ford dealership within a two week period to fix the problem, and even then the service rep flat-out lied about the real fix, after they first replaced the O2 sensor, and then the plugs, and then the plug wires, and after which I stopped paying for their guess work.
Dirty fuel or air filter, or low fuel pressure?
A smooth idle is a good sign, and obviously an engine doesn't need as much air/fuel at idle.
coupedncal
GerryO wrote:Based on an experience with a dirty MAF in my '97 Ford F-150, cleaning your's is a good idea. There are links out there to do-it yourself MAF cleaning instructions.
Thanks for alll the replies. Plugs have about 20k miles on them. I will look around for do it yourself links for cleaning out MAF and O2 sensors. Could someone paste the link if possible? My symptoms are pretty similar.
I couldn't locate the links when i looked here last time. Thanks again.
elan
Car: BMW 328I, Had J30 95,
have you ever cleared hte EGR tubes and checked the EGR valve ? I had a jerky pick up on mine cleaning those removed the effect. I did not have misses though
GerryO
Car: 1993 J30t
Pearl White
Black Interior
http://www.q45.org/maf.html
It's a Nissan at least and those for all makes are very similar.
unc1334
Car: 1993 Infiniti J30 Gold Package
It is definitley your MAF sensor, mine was doing the exact same thing this week and she is currently in the shop getting fixed right now
