95 J w/ intermittent hesitation
johnson_michael_l
Car: 1995 Infiniti J 30
I have a 1995 J 30 with 132,000 miles. I have driven it for the last 90k and have experienced intermittent acceleration hesitation the whole time. Sometimes the car has very responsive acceleration and I never have issues at highway speeds. It actually feels like a dead pedal and is very sluggish at RPM < 2,500. I use 93 octane fuel and have had the car maintained at Infiniti. Why would it not occur all the time? Any thoughts???
gr8scott72
Car: 1994 Infiniti J30t
Bad knock sensor is the first thing that pops in my head.
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
i vote for tps.
ropace37
Car: 1993 INFINITI J30
Ya I got the same problem in my 93 j30. to idles rough and shakes at low rpms, get to about 2500 or 3000 it smoothes out....really rough at idle and it smoothe when i let off the gas, real sluggish off the start, first was told it was cat, but then ign coil, i was wondering if any actual owners might have a hint....thx fellas
driverdriver
Car: NICO's longtime resident Canuck!!!
I had that.
Idles kind of like my old Buick Grand National at a light.
Its indicative of either a faulty ignition coil or in my case a faulty fuel injector.
Pull the engine cover off. Get yourself a decent multimeter(there pretty cheap these days) and test. You should be getting between 10-14 ohms per injector. If its below or above that range. First check the ignition coil. The way you do that is to swap in a new or working coil. If your engine smooths out, you've solved the problem. If it doesn't you need a new injector.
ropace37
got an easier fix 5-8 dollar bottle of lucas tune up in a bottle, guess i just got some bad gas, but shes back to normal again...thx all
