bnastyy87 »
https://forums.nicoclub.com/bnastyy87-u230340.html
Fri Jan 17, 2014 9:24 am
Hello all , I have a 1995 Hardbody with a ka24 , having issues with it breaking up at higher rpm in all gears. I have replaced the ignition coil , plugs , wires , rotor , cap , o2 sensor and fuel filter . tested fuel pressure , tested MAF , it doesnt throw any codes. if you step on the gas at idle it breaks up. 1st gear loses power around 4k rpms , and then breaks up in every other gear around the same rpms. Any ideas?
