Hoping someone on here can help me out with my situation....
Right now I have the aluminum Hitachi Maf Sensor that originally came with my 1995 nissan hardbody vg30e 4x4.
I recently sucked in alot of mud/water and blew the stock vg30e motor. The sensor is obviously covered in mud as well, and reguardless of it working properly I would like to replace it. Since I have an extra Maf laying around, I was just wondering if I could replace it with the Maf Sensor that I have from my 1995 240sx (ka24de). I have the pigtail harness and it is a three wire swap over. This maf sensor is a JECS and is plastic, in addition it has a much better flow design to it, which would be a benefit as well since the engine I just installed into it my truck is the slightly larger vg33e from a qx4/pathfinder/xterra
Basically... Can I use the pigtail from the 95 240sx maf and wire it into my harness and run the 240sx maf without having to retune the ecu or Run an apexi S-afc?
PS: Im running all stock hardbody sensors/harness/ecu. And i also realize i can clean my original maf sensor (which i have already done), but i am still curious if i can use the 95 240's maf.
any info is greatly appreciated.
Heres a picture of the two mafs...http://www.heavy-pork.com/truck/maf-sensors.jpg
