elvis240sx »
https://forums.nicoclub.com/elvis240sx-u1160.html
Wed Sep 12, 2007 5:16 pm
OK, I have already searched and came up with nothing. The car is a 93 Infiniti g]G20, but last winter I swapped in an engine from a 95 G20T. I used the newer G20T wiring harness and ECU. The car ran great until about April. Since winter was over, I just put the car away and got the 240 out.
The problem was, the car would idle fine, but suddenly had no power. Literally, it would not get out of it's own way. At about 4500 to 5K RPMs it would start to pull harder and seemed to run right. I didn't bother fixing the problem until now, as i am trying to get the car ready for winter.
I replaced the plugs, wires, cap, rotor, fuel filter, air filter. It still did the same thing. I noticed, however, that the #2 spark plug looked perfectly clean, but the other three looked like a nice burn. I checked for spark, and they all had spark. this led me to think a bad fuel injector. I had four extra injectors lying around, so I pulled the plenum off and swapped out the #2 injector. after putting it back together, I started up the car and it ran great! I ripped up the road a couple of times and everything was fine.
I then started the car back up after a few minutes and it started hard, but then seemed to idle fine. When I pulled out of the garage, the car fell flat on its face. If you just open the throttle normally, or pull it open quickly, you can hear and feel the engine just bog down. The engine will die if you hold it open, it just dies out very quickly. It sounds like the car is running out of air almost, like choking. Now heres the weird part, if you crack the throttle really slow it will rev up all the way to redline. If you rev it slowly up to the upper RPMs then whack it open all the way quickly, it still bogs down but not nearly as much.
What iI determined:-all cylinders getting spark-charging at 14volts-fuel pressure 40psi at idle, climbs to 50psi when open throttle-unhooked MAFs, car runs the same or slightly worse-took airbox off to test for air restriction, didn't help-compression all about 170psi except cylinder #2 is about 155-160psi-sprayed carb cleaner all over intake/hoses, cannot find intake leak. -when putting head over engine it sounds like air blowing (intake leak) but could also be electric fans or p/s belt? ?
Any help would be appreciated. I am wondering if this sounds like an intake leak? Or would it be more of a sensor / wiring problem. It just seems weird that if you open the throttle really slowly, it can rev way up. If you whack the throttle quick, it just falls right on it's face. It seems like maybe the ECU can't adjust fuel or timing quickly enough to handle the increased air / load? I dunno. Any help is appreciated
