thomcycle »
https://forums.nicoclub.com/thomcycle-u697.html
Tue Jun 17, 2003 4:23 pm
I'm replacing the water pump on this G20 I purchased recently along with all hoses, belts, and fluids. The water pump was a bear to get out and I'm wondering if there is a trick to keep the liquid gasket bead intact while weaving it back into place?? I removed the front engine mount and wedged a block of wood to maintain maximum clearance between the engine and the wheel well ( the pump came out from the top). Any advice is welcome.
Thom94 Q4595 G2087 535is
