JustinP10 »
https://forums.nicoclub.com/justinp10-u16125.html
Sat May 01, 2004 6:18 am
Well, I noticed that when the motor mounts are REALLY worn out that shifting is crappy, because the motor isn't aligned properly with the shift rods. My stock mounts were ok (I recently had replaced them) and then I swapped in a set of Place Racing mounts and it made the shifting that much easier... good fluid helps too.
It could very well be something internal, but if your motor mounts are really bad, it could be that simple and it'd be a much cheaper solution/fix...
