lowpass5 »
https://forums.nicoclub.com/lowpass5-u53662.html
Sat Jan 06, 2007 11:11 am
Hi,I'm new to this forum. I have a 95 G20 that won't pass emissions. I was wondering if any of you know the correct O2 sensor voltage for this car. I am reading 0.94 volts fluctuating some, but not significantly. I was expecting something around 0.45 volts. I notice that I get about 0.3V bias with key on engine off. The sensor responds quickly to induced vacuum leaks but returns to around 0.9 even in the presence of a leak. I checked the engine temperature sensor to make sure the computer has the signal to go into close loop - it is working fine. It acts to me like it's not using the O2 to control the mixture, but the vacuum leak response puzzles me. When I pull the hose, the reading drops to around 0.2V, the recovers to around 0.9 and stabilzes. It's less than the 0.94 without the leak, but it seems to be responding. Does this seem correct?
The car is not posting any codes. i have had it to 2 repair shops without any results ( but with significant cost). Any advise of a non-suicidal nature would be greatly appreciated.
