95' Factory Service Manual doesn't tell how to change speakers?
Mugen13
or maybe I just can't find it. Is there a good write up for installing components on a S14? Where did you guys mount your crossovers?
I seriously dont know why they dont tell you how to remove certain parts like the A-pillar covers, but they can tell you how to basically make the car :confused:
nismofan14
To remove the doors there are 3 or 4 screws in the bottom, 1 in the door handle and another in the handle below it that you pull the door shut with( a little cap covers the hole , pop it out first) the rest of the door is held on by clips so just pull carefully. The A pillar is held on by clips so just pull it off and you can mount the crossover anywhere you desire. When I had mine I just lengthend the wires long enough to hide them up under the dash.
