whomadewho »
https://forums.nicoclub.com/whomadewho-u165512.html
Mon Jan 27, 2020 12:24 pm
As far as the lower part of the core support being rusted out. Possibly that it can be repaired by cutting out the rusted section and welding a section of square tubing or flat iron to support the bottom part of the radiator??? Make sure the headlights are functional and can be aimed. If the truck has A/C figure in more $$$$$ . Beyond that I would not recommend taking things apart. Say the engine went bad and to save $$$- you removed the engine and tore it down and brought it to the mechanic to fix it. Can only imagine what he would tell you. Hows the rest of the body? Most of them you don’t want to transport a pet to the vet for fear it won’t be there when you arrive?
