Hello everyone, I'm a refugee from the J30 forum. I just picked up an s14 from a young kid stuffed with a blacktop sr20 engine and trans being run by a Power FC (alas, sans the hand held Commander). The car was apparently tuned pretty well, as it drives nicely and pulls surprisingly hard at only 7 lbs of boost on the stock turbo with FMIC, intake and full exhaust (easy 200whp on my butt dyno). I don't know who performed the actual physical conversion, but it does not appear to be a hack job. Indeed, the car only has two issues which are vexing me.
The first issue is the trans mount. Apparently Nissan does not even list a part number for a '95 5 speed transmission mount, but this vehicle has what sure looks like an automatic trans mount stuffed between the trans and the cross member (I have no idea if it's a 5 speed or an auto crossmember, which appear to look pretty similar). This set up would not bother me but for the fact that the rubber portion of the mount has partially collapsed leaving metal on metal contact transmitting LOTS of vibration in the cabin. So my question for others who have performed this conversion is: What are you guys running with; just a KA 5 speed crossmember? If so, how is it physically connected to the trans, via rubber bushings?
My second issue is the darn reverse lights. I purchased a KA manual switch to connect to the sr trans, but then discovered that the harness was not transmitting voltage. I've reviewed the following how-to at
http://www.nicoclub.com/archives/automa ... -swap.html, but in looking at my passenger side kick panel I do not see a plug that fits the photograph. So my question is: where is the correct plug located on a '95 automatic car?
Thanks for any help you can give me.
