95 Altima won't start
Robert Thomas
Car: working on car, working on cars
Ck eng light came on Thurs, drove car Thurs & Fri. No change in perf. Sat. retrieved code 55 normal operation. Cont. using car, no change in perf. until Wed, while driving with cruise set at 68 mph car bucked 2 or 3 times then shut down. Eng turns over but will not start. Fuel pump & spark OK.
NISTECH
Remove the distributor cap. if oil pours from it you need to replace the whole distributor as the internal seal has blown out and to my knowledge the seal is not replacable. The dist is like 500 bucks. I have been able to get them to fire up and drive a bit for what I needed by removing the black plastic cover under the rotor and spraying the sensor underneath the cover off with brake clean. then I reassemble it and it usually fires up no problem.
bigdaddy008
You're right, took off the plastic cover and oil poured out. Would a dist. from a 97 Altima GXE work? A nearby scrap yard has one with 30,000 miles I've been getting parts from. Thanks for the help.
bigdaddy008
you're right took offthe plastic cover and poured out. would a dist. from a 97 altima gxe work? a nearby scrapeyard has one with 30,000 miles I've been getting parts from. Thanks for the help.
NISTECH
I do believe it will work I will post if I find out it wont.
