Changed plugs, distr. cap and rotor, fuel filter(was perfectly clean) and sprayed MAF sensor. car runs ok for a few minutes then starts to randomly miss. Have oil leak by distributor and have replaced the distributor a few years ago--but leak is back.
So, is there a way for me to 'clean' the sensor/eye in the distributor? I don't want to change it out if I can avoid it.
Also, anyone know of some good sites to order a distrib. on-line?
And is it someting I can change myself if i mark the position of the old one?
Can/should I pull the distr. shaft out to find the leaking o-ring--where is the leaking o-ring?
Thanx dudes/dudettes
