Mealticket »
https://forums.nicoclub.com/mealticket-u253227.html
Sun Jun 21, 2015 7:33 am
All - new to this forum, do drive a 2007 Sentra myself but all it has needed is oil changes. Trying to help out a really nice older lady I know who has a '95 Altima 2.4; she is getting ready to junk it and I said hold on. Couple people told her blown head gasket but I see no evidence of that at all. I guess it did get hot or overhead at one point. Ran compression test and got 150, 140, 120 and 120 in the 4 holes. It doesn't run too bad and she can drive it around town.
Although she says the CEL wasn't on originally when she started having problems, it is now. Scanned it and got P0325 (knock sensor), P0300 (random/mult cylinder misfire), and P0301 (cylinder 1 misfire). It also shows 3 'readiness not complete': catalyst, O2, and EGR and/or VVT. When pulling plugs for compression test two of the wires had the hard plastic section break off, and one electrode pulled off the wire and stayed on the plug. #4 wire boot also clearly wouldn't sit flush on the valve cover, even when you tried to push it down, but the plug end didn't show burning from arcing. Plugs don't look too bad, no coolant or major red flags. One of the hoses at the charcoal canister has a huge hole in it and I will replace that.
We're both on a budget. My plan would be to do the plugs and wires, cheapest way possible, and maybe cap and rotor, then see if the P0300 and P0301 codes go away. Is there a way to test the coil? Also I see many posts online that say that on these cars the knock sensor wouldn't set the CEL, but from my own experience on a Pontiac Bonneville, it absolutely did on that car. I won't touch the knock sensor unless I have to. Thanks for any help,
MT
