Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon May 25, 2009 4:57 am
Important to understand WHY the transistor assembly fails FROM a worn out fan motor that is drawing beyond design point current.
As electric motors wear out they turn slower and draw more current, evenyually this extra current grossly overheats the transistors and they fail creatinng an open circuit in the assembly.
The HVAC ecu senses this and command the high speed relay to close as a warning that the transistor assembly has failed and as a fail safe to maintain air flow.
HVAC fan motors have a ~~ 10 year life by 14 years they almost all fail, of course depending on hours of use.1 hour per day 365 x 14 is 5,000 hours. 2 per day is 10k hours.
