jims72 »
https://forums.nicoclub.com/jims72-u229650.html
Wed Jan 22, 2014 10:17 pm
I have a 95 hardbody 4x4 2.4 ka24e and i have a problem with fuel getting into the oil. Im not talking just a little fuel either. I drained 3 gallons[ yes i said gallons] of fuel and oil mixed out of the engine when i received the truck a month ago from my neighbor. he tried replacing the fuel injectors but got the same out come so he just cleaned the old ones and slapped them back in with new o rings.I have removed the fuel rail and checked for leaks by turning the key to the on position with the injection wiring unhooked and got no drips. I have also rebuilt the entire engine because I had found low compression in all four cylinders and the timing chain was stretched out causing the engine to pop.all of those problems are now fixed but its is still filling up the pan with fuel. I have noticed that it seems to happen worse/or mainly when under a load and being driven. It fills so far up in about 2min that oil is pumped out the tail pipe ! I need some help identifying the cause of this problem. I have also looked at the fuel pressure regulator and have found the vacuum side to hold vacuum and fuel does flow to the return line with the key in the on position and there is good vacuum at the vacuum line for the fpr. cane some one help me please?!!!
