95 240sx wont rev up
i4jdm
Car: 1995 240sx (s14) kouki conversion
hey i need some help. the distributor on my car went out so i changed it out. car was running fine before the distributor went out. i changed it and now that i put in the new one the car will start but wont rev up past 1000rpm. could it be the timing? pls post back. thx
zerepdivad
Car: '90 240sx . '02 Lexus IS300
You most likely simply just put it back in wrong. You're most likely off a tooth or two.
Set the motor at tdc for cylinder 1 and when you put in the distributor the rotor should face the beginning of spart plug wire 1. At least on mine that's how it went...
i4jdm
th
zerepdivad wrote:You most likely simply just put it back in wrong. You're most likely off a tooth or two.
i could try agian but i did put it in at top dead center.
smoothlikewater
your timing is off forshure, recheck it make sure your motor is on tdc, and line up the distributer, though the dualcams distributer is the most bitchiest thing to put in
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
make sure you did not disconnect the airflow meter
i4jdm
koo got it goin....everythings ok an im not pissed any mo......
