95 240SX won't start
Midnightoker91
Car: 1995 Nissan 240SX
Hello all, new here.
Having an issue with the unit starting. When I turn to the accessories everything works. Fans, lights etc.. As soon as I try to turn to ignition to start it everything dies.
Battery is new.
Did notice that the ECUs lighy is not coming on it that helps. Any info where I can go from here would be helpful. Tried 2 ECUs.
Reason: Revise Title
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Sounds like a bad ignition switch:
White/Blue: Acc or On
White: On only
Black/Red: On or Start
Black/White (and Black/Yellow if present): Start only
Midnightoker91
Okay, ill give that a test. Would that also effect the ECU from coming on. Not getting a 12V constant on my voltmeter from PIN 58.
VStar650CL
Technical Expert
Sure. If it's not getting an ignition signal then it won't power up.
PapaSmurf2k3
Site Admin
Check your battery terminals as well. If they are corroded, it could have enough power to turn accessories on, but not enough to juice the starter.
