95 240sx w/98 5sp transmission issues
i_need_an_s15
Car: 95 240sx
Hi everyone, im having some trouble with my s14 bucket. This car was an automatic in the beginning, but I bought it converted to a 5sp using a 98 240sx transmission. At first the car was shifting perfectly but then one day outta nowhere it started to get harder and harder to get it into gear while i was driving and also when im not moving at all, just idling. It only does this when the car is turned on btw. Anyways every now and then the transmission will act as if nothing is wrong with it and other times its a b**** cause I wont be able to get into gear unless I rev up or down to 2k rpm. Im stumped cause I have no idea wtf the problem is and its been doing this for a few months now. I took off the shifter assembly and found that the bushing for my control lever socket (the very bottom of the shifter) is broken...i think. This is where yall come in to save the day....does that piece being broken affect my transmission from shifting? The way I see it, that bushing has to sit in its housing in the transmission and not move up and down the shifter like it does or else it will cause play in the shifter itself and not allow the bottom of the shifter to properly engage into whatever gear you want. Someone please either correct me or advise me on what to do Last thing, it does it for every single gear....reverse is the biggest pain in the a** to get into, I have to slam it into it.
[IMG][/IMG]
i_need_an_s15
Car: 95 240sx
bump...
Dazzla
yeah you need to replace that little bushing...I think that will fix your problem. It's not suppose to be able to move that far up the shift stick thingy. It should be around the ball on the bottom and thats it, no further up because then its pointless lol
i_need_an_s15
Car: 95 240sx
.....anyone else have any input?
mastakilla08
Car: 1992 hatch, 1989 piggy coupe, 1991 coupe silv.
ya replace the bushing.... or u can get a megan short shift kit for 40 bucks... btw u wanna fix this as soon as possible because every time u slam it into gear ur knarin up ur spider gears and syncros!! one day ur transmission will just stop working.. happened to me
blackandblue
Car: 1995 240sx base w/ vlsd sway bars drop springs intake exhaust rims..
This is way late, but what does your clutch pedal feel like? Did u drive it as an auto? Have you driven a 5 speed 240 before your swap? Who did your swap? Is the clutch noisey?
