teddy »
https://forums.nicoclub.com/teddy-u22985.html
Sun Jun 25, 2006 7:33 am
The power steering pump would have nothing to do with your current problems. The power steering system is completely separate from the engine except for the belt that powers the pump.
Since the car has been sitting for a while, I'm going to assume that you've got old gas in there, and probably didn't put stabilizer in it 7 months ago. Having some fresh gas should help clear the engine up some.
It also sounds like you've got a vacuum leak somewhere, which would cause the surging idle. Backfiring is also caused by rich fuel conditions, and this could explain the bogging. You may have an injector stuck open.
I would go ahead and do the plugs, wires, rotor, etc just because it's good maintenance and should be done anyway, and add fresh gas and see if that helps clear things up. Then search for any leaks in the vacuum hoses, or brake booster line. After that, if the problems are still persisting, you'll have to start checking the injectors.
