crackler »
https://forums.nicoclub.com/crackler-u26495.html
Sun Oct 30, 2005 11:33 am
I have 92 5spd 240sx w about 120xxx miles on it.I have two problems and I dont know if they are related or not.
One problem is it is running rich at idle and I am assuming all the time due to my poor gas milage (more on this later). The other problem is my speedo is way off. at 35 miles an hour it was reading 40 at 65mph it was showing 85mph (confermed via handheld GPS) and sometimes when cruising at a steady speed, say 65 it some times will jump back and forth between 65 and 85 usally winding up at 85. It doesnt matter what gear im in, the speed is always off, the faster I go the more its off. I was wondering if this had anything to do with the car running rich off idle, also if I should get it recalibratd, relpaced or something else. And one other thing, I think my gear sensors all apear to be covered in grease/oil, I dont know if this matters or not but I thought I would mention it.
And as far as the running rich goes, It has:
New NGK Iridum plugs (also used NGK-R, same effect)New Borge Warner wires, car, rotornew Bosch O2 sensorNew Wix Fuel filterseafoamed intake + cleaned w carb cleanerLucas gas + upper cylinder treatmentNew ECU temp sensor (it thew a code for this, it went away after I changed it)Timing set at about 20 +/- a littleIdle is set at about 750 +/- a littleFuel pressure is good I think it was 44 at idle and between 44 and 30/35 under load (I cant remeber for sure)
Most of this stuff i changed / did when I bought the car, since I didn't know the last time it had been done. The ECU temp sensor I replaced when I threw the code. it the ecu reads 55 now, wich I beilive is no codes present. I have also wiggle tested the injectors, they seem fine. All the injectors seem to be firing okay (they all click anyway). I dont know where to go from here, and I dont feel like or have money to throw parts at. So anyhelp would be greatly appreciated.
Thanks
D
