95 240sx rear thumping
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Ok, whenever I shift gears there is a very loud thump in the rear as if the whole rearend is going to fall off. Also, if i'm going at a very slow speed like 5 mph or so and just barely pull the parking break it will make the same noise. anyone have any ideas of what could be going on? Thanks!
Phantom
I'm not too familiar with those kind of things but it sounds like what the obvious thing may be is that its not engaging correctlyand not quite locking strait so when you do let off the clutch of E-brake it slips into gear making that thud.
What probably needs to be done is to take apart the transmission case and make sure the gears and bearing are strait and in place. That or your throw out bearing may be gone. So take it in to Nissan and have it looked at. Good luck.
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
Sounds like the rear subframe bushingsto me.
mtcookson
1992 Iinfiniti Q45
and much much more
i was thinking it was the bushings also. any writeups?
groundhogday1976
Car: 2015 Altima 2.5 S
Could be a bad universal joint.
Holisticbeatz
A few months ago, I heard a loud thumping noise coming for the rear of my car followed by some faint voices. It freaked me out a couple of times so I didn't dare to investigate what the problem could be. After a few weeks passed, the thumping noise ceased, but I began noticing a strange decay odor. The smell bothered me enough so one day I opened my trunk. Inside I found a family of Mexican farm immigrants. They must've hid inside the trunk of my car while I was partying my a$$ off in Tijuana. Anyways, you should check your trunk for illegal immigrants.
f8sjester
good call hollistic. . .it's always the last thing you think about . . . heh
mtcookson
1992 Iinfiniti Q45
and much much more
:rotflmao
well... i don't think any would fit because my brother has this huge sub box with a JL Audio 15 W3... they could have thrown the box out but the trunk is kind of hard to open. i think we're getting close though :)
