95 240sx problem with key cylinder (tumbler)
salvys14se
Does anybody know how to remove the lock cylinder I removed the trim around the stering wheel I tried putting the key in acc and pushing the little pin on the side of the lock but its not coming out is there something I'm missing. My key broke inside I'm still able to turn it and drive the car but I want to fix it.anybody knows :gotme
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Ask the Nissan dealer for a print out of the part diagram, they should know.
comatoseculture
Car: 1990 240SX coupe. Currently running on Megasquirt.
That ish has tearaway bolts. Not an easy/normal thing to do sir. I really don't know what to recommend. I actually do have a spare ignition cylinder with a key, but as I said the connecting bolts shear away and these were hacked off. No easy chance of install as far as I know. If you really need/want you can hit me up for the cylinder, but either way talk to a mechanic preferably someone into nissans to determine the amount of work required, or if it's even easily possible.
