Twilight sentra tuner »
https://forums.nicoclub.com/twilight-sentra-tuner-u65262.html
Fri Jun 22, 2007 7:22 pm
i don't think it would be ur thermostat. that would have to stay closed in order for the car to overheat. if that was the case the temperature would just keep rising. but the car squeeks. sounds like it could be ur water pump. the water pump sounds like it can't keep up with the engine itself.
try checkin for any leaks within the cooling system. hopefully its external. if its internal then that means ur coolant is gonna mix with ur oil making it lose its lubricating abilities. that can eventually lead to ur bearings and bearing inserts being shot. and thats really expensive to repair.
question. is it the original radiator?
