95 240sx not cranking
jessead82
Car: 95 240sx
Hello everyone. Have a problem that I have been about to pull my hair out over. I have 95 240 that will not start. This is what happen to lead up to the problem. I just finished installing a new head unit and was playing around with it and drained the battery to much to turn the car over. So I hooked up a battery charger to the battery and let it charge a little. When I turn the car over then it turned over a little but not ebough to fire. The charger has a cranking start option. When I switched it to that option the car turned over to start and then all hell broke lose. I heard a loud clicking noise coming from the fuse panel box on the drivers side and my digital clock went blank. I found the fuse for it (with some help from some on here) and replaced it. The Clock is working again and I changed the battery for a new one. Now when I try to crank the car nothing happens. I have checked all the fuses one by one and have just checked and the relays in the fuse panel and they are all fine from what I can tell. I can hear the fuel pump prime when you turn the key but nothing when you try to start the car. Its also a manual if that helps. Any help with this would be great or if there is anyone in the Birmingham,AL area that would be willing to take a look at it would be awesome. Thanks Guys
Dazzla
Do you have an alarm/immobilizer in the car?
zach-Ka
Car: 1990 240sx (SR)
Maybe you fried the starter?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Don't use the start on the charger. Charge the battery completely. And try again.
jessead82
Car: 95 240sx
No there is not an alarm on it. And I have put a brand new battery in it and still nothing.
jessead82
Car: 95 240sx
Thanks guys. I found the problem. The little rubber grommet on the clutch pedal fell off. A 5 cents rubber grommet was kicking my butt. /sigh
