navysnail »
https://forums.nicoclub.com/navysnail-u13430.html
Mon Sep 15, 2008 4:51 pm
its really easy, there is a side fill hole and a bottom drain hole. open both to drain, close bottom one, open side to fill with a fluid pump if you have one. MT90 is probably the best, but any 75w-90 will work. nissan recomends a non synthetic, because synthetics are too slick, and will interfere with the synchromesh mechanism
