Postby
dalzell240 »
https://forums.nicoclub.com/dalzell240-u51411.htmlWed Mar 28, 2007 11:50 pm
got a 95 240sx stock motor, injen air intake, and catback exhaust,since we put got it back up and runnin after a few months it keeps overheating bad.we changed the thermostat, water pump, radiator fan fuse, flushed radiator, bled the cooling system many times and it still overheatswe dont know what else to do, any advice could help, thanks
Postby
Unit-121 »
https://forums.nicoclub.com/unit-121-u61060.htmlThu Mar 29, 2007 10:50 am
Hey try to see if your heater core is running good and all hoses connected is tight. I had the same problem on mine until I checked everything. Hope this was usefull
Postby
93HATCH240 »
https://forums.nicoclub.com/93hatch240-u40914.htmlFri Mar 30, 2007 7:39 am
Make sure you got all of the air bubbles out. I thought i did when i did my t-stat and it still kept overheating. I changed my water pump with a new one but my old one still looked good. It turned out I didn't bleed the system properly.
