95 240sx KA transmission grinding
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
OkMy 1995 S14 has a problem with intermittent griding of gears, primarily during the 2-3 shift, reverse, and 1st gear.
The tranmission is 'new' ~100k miles with a clean gear set that was swapped into my current bellhousing. The clutch is new, and the only other problem I can see is the clutch pedal has short travel and needs to be adjusted
My initial though was it was the synchros but during shifts sometimes its very difficult to shift into gear so I double clutch but it doesnt help at all. The problem is random, maybe 3 times a day (50 miles) and is bugging me
The shop that the transmission came from is saying its probably my driveshaft bearings because in the past I had major subframe bushing issues that caused my subframe to move up and down 1/4-1/2 inch.
Its a bit complicated but I'm wondering what possible issues are there out there to cause transmission grinding issues other than synchros?
Can a bad clutch master/slave cause trans grinding?Misadjusted clutch pedal?bad driveshaft bearings?transmission mounts?
let me know if you can help me out!
thanks!
navysnail
adjusting the clutch pedal is the first thing to do. if the clutch is not completely disengaging, that would cause grinding so eliminate it first.
FRoSt415
Car: s13 240sx
their is a bolt on the pedal i think its a 12 mm just adjust it where the pedal is higher and make sure it has about 1/2 inch of freeplay. besides that did you install the clutch? might not be alligned right.
