Hello everyone. I'm wondering if any s14 owners can help me out with this one. So my gf's s14 had alot of issues when she bought it and now most of them are taken care of. But this current one is giving me some trouble. The dome light and door ajar light dont come on when you open the driver side door only. They both work when you open the passengers side. So the driverside door switch or wiring is bad. so I test the switch and it is indeed bad. pins 1 and 2 should both ground out through pin 3. pin 1 for the airbag computer grounds out to pin 3 but pin 2 for the lights does not. so ok I order a new switch from nissan get it and it tests the same way!
I can put a jumper wire from pin 1 to 2 and a wire in pin 3 and touch them together to simulate the switch being there and all the lights work! So did nissan sell me the wrong part? this switch they sold me grounds pin 2 for the light to the screw that holds the switch down. but the screw goes into a plastic insert in the door frame so how is plastic supposed to ground anything out?
So is there a ground wire that is supposed to go to the screw? So maybe one of you guys with a s14 and a working dome light and door switch could test your switch for me or let me know if there is supposed to be a wire going to the screw? The FSM states that both r/w and g/r wires should ground through the same spot pin 3 black wire.
