whokid978 wrote:Hey thanx for the help, but now my car starts now when I jus left it there for 2 day. I didn't do anything to it yet and it jus starts up. Do u think it could b the transmission fluid?
Looks like an intermittent problem with either the fuel or ignition. Next time it doesn't start, check each plug wire for ignition by using a spare spark plug; with a plug wire connected, lay the plug on the valve cover and look for a spark when turning the motor over.
If that's OK, do a quick check for fuel like this:disconnect the fuel hose from the top of the fuel filter and insert a long length of spare hose into the top of the fuel filter with the other end draped over the fender going into a catch can placed on the ground. Now turn the ignition key to the run position but DO NOT START THE ENGINE. You should see fuel going into the can at a good rate for several seconds.
The ATF is checked while the motor is idling; make sure the transmission is fully warmed up.
