Postby
jessead82 »
https://forums.nicoclub.com/jessead82-u139783.htmlSun Oct 11, 2009 4:42 pm
I have a 95 240sx that I just finished installing a new head unit in today. After playing with the radio for a few minutes I noticed that I had drained the battery to much to crack the car so I tried to jump it off. After I jumped it I heard a clicking noise coming from the fuse panel and thats when the clock on my cluster went blank and the radio stopped working. I have checked all the fuse and they are all good. Everything else is working. Any help on this would be great. Thanks Jesse
Postby
VRoy »
https://forums.nicoclub.com/vroy-u131583.htmlSun Oct 11, 2009 4:46 pm
Off the top of my head i would check the little white box by the fuse box, it has something to do with the clock. I'm sure someone can explain this a little better.
Postby
MarkRipoll »
https://forums.nicoclub.com/markripoll-u100688.htmlSun Oct 11, 2009 5:01 pm
Check all your fuses by the drivers side kickpanel again, i had the same problem after i took my car to get the exhaust finished, i guess a tech liked the music loud on the "test drive" really loud I believe the fuse was brown in color.
Postby
jessead82 »
https://forums.nicoclub.com/jessead82-u139783.htmlSun Oct 11, 2009 5:12 pm
You're a genius. I went back out and checked all the 7.5 amp (brown) fuses and sure enough I found a blown one. It was the Electronic Battery Fuse. Going to O'Rileys to get a new one tomorrow. Thanks Guys for the quick help.
