95 240sx : climate control blower only works on high.
obos
95 240sx - My climate control only works on the highest setting. Do I need to replace it, or is there something else I should look at first?
Thanks in advance...
NISTECH
Blower resistor is blown. it is in your heater box. held in with 2 screws near your glove box area.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
Finally!!! i can fix mine too, i've had the same problem for 2 years now!!! thanx nistech!!!!!!
NISTECH
keep in mind the blower resistor usually blows out due to a high current draw from the motor. It can take a yr or so of use before it would blow again or it could never happen as something may have been in the squirel cage dragging it down and now its gone. When you go to replace the resistor drop the motor out of the box and make sure nothing is in the cage.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
gotcha! thanx buddy!
