95 240sx check engine light?
bullet@TheBeach
Car: 1995 240sx/se
I had a check engine light come on last night. Is there a way to check the codes to see why it came on? thanks.
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
How was the car running when it happened? did u install anything new such as an aftermarket intake header or exhaust??
bullet@TheBeach
Car: 1995 240sx/se
I installed 91 cams about 3 weeks ago. nothing else since then. Is there a way to check the codes to see what it might be?
180fan
Car: 89 fastback
pull up the code it's throwing and post back which code the ecu is throwing.
bullet@TheBeach
Car: 1995 240sx/se
I don't know how to pull up the codes. That is what I am trying to find out how to do. Can anyone help?
ricebike
2002 Quest
2005 Altima
welcome to NICO!
ok, i searched for u... www. 240sx. org in da FAQs section
click me!
click me 2!
don't forget to d/l the FSM! for more info
ps: i dunno if some later models in that year started using OBD II connectors (look around)
& if u find one, goto nearest autozone for free code scan if
u don't want to take passenger side kick panel off/ unbolt ECU/turn it around/ fiddle w/ the screws
OH PS: check / write down trouble code/ reset ECU/ then drive until light goes back on to verify that there's a real problem & not a ghost/electrical hiccup
WI_S14_Goldie
bullet@TheBeach wrote:I installed 91 cams about 3 weeks ago. nothing else since then. Is there a way to check the codes to see what it might be?
Hey sorry to get off subject here, but how do those 91 cams work for you? Cause i have a set in my room waiting to be installed, is there any noticable difference? Do u like the cam swap compared to ur old setup?
bullet@TheBeach
Car: 1995 240sx/se
I found out what the codes were: 65 and 34 Cleared them and they have not come back. As for the 91 cams. I can tell they are in there. I can feel more torque more now than before.
