95 240sx auto transmission problem
KevinFD3S
Car: S14,E46 M3,FD3S,NA1,NB8,Saab9-2X,ML430,RV
this car is bone stock,after turn on the engine, the "O/D off" light will flash 16 times then go off. while driving, the transmission won't shift up unless you reach red line...Does that mean it's time to change the transmission ? this happened after i wash the engine room..... maybe it's has something to do with this problem.
I found some topic about flashing OD lights...but that's for a 92 240...are they the same?thanks
Modified by KevinFD3S at 10:13 PM 8/26/2006
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Yes, washing the engine compartment without protecting the harness connectors can cause major problems. Check out the TPS harness connector for moisture and oxidation of the pins; the TPS has a direct effect on how the auto transmission will shift.
KevinFD3S
thanks a lot.... when i unplug the TPS....a lot of water comes out...
and then...it runs like nomal...but OD lights still flashing(who cares...)
thanks again....
93inHOU
Car: 1993 240SX SE Coupe
I rinsed down the engine bay on my '93 240 SX with an auto transmission 3 weeks ago, then did not drive the car for about 2 weeks. Now when driving it, I have to let off the gas (like driving a manual) for the car to upshift. Where is the TPS Harness and what does it look like? Maybe I've got the same issue with damp connectors.
