NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sun May 22, 2005 5:43 am
As Chris said the rear O2 has no effect on fuel control. It is only used for Cat effeciency monitering. It basically is designed to let you know when the cat took a dump.
If you want this car to run as claen and as effecient as possible you need to focus your diagnosis on the front O2 once the car is warmed to operating temp. During cold start up and any other time you also need to look at MAF operation, Coolant temp functionality and accuracy. Crank angle sensor signal, Basic ignition component condition such as cap, rotor, wires, and plugs.Check and set basic ignition timing to spec. Other fuel system components too look at are fuel filter, leak down check on injectors, compression of cylinders. These are just to name a few things to look at for proper 4 stroke engine efficiency.
