jordanmullen »
https://forums.nicoclub.com/jordanmullen-u84524.html
Mon Dec 24, 2007 10:07 pm
so let me get this right, the car has been cranking slowly for a few days and now dose not crank at all. The alternator will not prevent the car from starting with a good battery. you hear the starer engaging, click when you turn the key. few things, try jumping the battery, just because it is new dose not mean it is good. turn your lights on and try to start the car, do the lights dimm? no, you have a electrical problem, the starter is not drawing power, get a wirering scem of starting sys. if they do, use a braker bar and try to turn the crank, if you can, replace starter, if you cant pull off the belts and check you accesories(alt, ps, ac) try to rotate crank with belts off, if you cant, you have a big prob. hope this helps. remember, it takes some force to rotate the crank by hand.
