bahamut »
https://forums.nicoclub.com/bahamut-u6894.html
Thu Oct 02, 2003 1:29 pm
It eats some oil and if i romp on it before its good and warm it'll smoke some. Lifter noise too! It runs strong though.=============================I have the same problem too, except the lifter problem. The injectors firing off is louder than the lifters, unless I hear it in the cabin.
The plugs condition should tell you if you are consuming oil. Oily plugs. ====================That's the first thing I checked before the compression test. A couple months ago, I have put new plugs, and the results look normal w/ carbon, not oily or stalactites of carbon buildup or residue.
Leaks, I may have a few leaks, but I can't really see around too may vacuum and emission lines. It's not dripping all over the block or onto the driveway. In the past, I had an Olds Ciera that had both bad cyl head and valve cover gaskets. It leaked all over the place, but it didn't consume this much oil or smoked at all.
No real emission laws in FL.
Wow, a rebuild will burn a hole in my wallet. Then again, I do have an extra cyl head, just need some time and effort to clean it up a bit . . . if the valves seals are bad on the running motor.
