acidx »
https://forums.nicoclub.com/acidx-u4166.html
Tue May 18, 2004 10:38 am
Ok, maybe someone on here can help me ever since I turbo charged my 240 and did the exhaust(no cat) as well as removing the entire egr system i've come up with to codes on the ecu.
One being a code 33 which is the O2 sensor the other being obvious which is a 32 or EGR system failure.
Now the questions are one do the single wire O2 sensors through a code based on a rich and lean condition like a heated o2 sensor(usually secondaries will do it with cat removal) or does it really mean the sensor is bad? The second question is for the egr code, how exactly is the ecu telling that the egr system isn't there if the solenoid is still connected? and is there anyway to fool the computer into thinking it is still there? or should I just go through and put it back?
