S14-KOUKI-MONSTER »
https://forums.nicoclub.com/s14-kouki-monster-u39701.html
Sat Aug 05, 2006 10:44 pm
As posted above, you should definately have your rotors machined(if within thickness specs).When you installed the new pads, did you bleed the brakes? Air acts like a spring while being compressed, and will leave a very soft spongy pedal feel. Most of my buddies just push the piston in, load the pads, and bolt it up, but don't take the 5 min to bleed . I personally like to rebuild the calipers too(so I have to bleed anyway), because it's a cheap, quick, and easy way to keep your brakes in good shape.
