95 200sx SE-R PROBLEMS!
TREMOR13
Car: 1993 se coupe with SR!
what up everyone could someone help me?iI have a 95 200sx SE-R i have p301 poping up i have a miss fire on cylinder 1 and have reallyhave crappy acceleration!!
nametakennow
Car: '06 MINI Cooper S
How many miles? Do you drive it hard?
Check spark plugs, fuel injectors.
TREMOR13
it has 148,000 brand new spark plugs and it's been driven very chill!!have u run into this problem before?
Diggs_B13
Car: B13 SE-R
TREMOR13 wrote:it has 148,000 brand new spark plugs and it's been driven very chill!!have u run into this problem before?
Clean your engine lately?Water down in the spark plug holes will cause symptoms like you are describing.
If you just changed your plugs, go over your work again. Maybe a spark plug wire has gone bad, or come loose.
Doug
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
TREMOR13 wrote:what up everyone could someone help me?iI have a 95 200sx SE-R i have p301 poping up i have a miss fire on cylinder 1 and have reallyhave crappy acceleration!!
Do you mean you are throwing code 0301? If so, you might want to get another ECU.
0301 ECM control unit The ECM input signal is beyond “normal” range
JDMEnthused
Car: Nissan 240SX
i grounded all of my spark plug wires before replacing them and found out that they were misfiring so.. i replaced them and bought all new ignitior components, minus the coil and.. it fixed the problem.
TREMOR13
well so far i have checked my wires changed the distro cap and checked basics is it hard to remove injectors how could i check them?
RED_DET
Vendor
2011 Infiniti G37x
JDMEnthused
Car: Nissan 240SX
i doubt he has even put it on a diagnostic on it..
