Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Thu Oct 27, 2005 4:55 am
Are the screws coated with some sort of locktite? Curious why they are set up as one time use? Can't be that expensive...
From looking at the FSM (EL-239), it appears that there's a horn relay in the engine bay fuse/relay box. It's grey and is the front one on the inside row (near the large fusible links). You should be able to unplug the relay and check the signal (input) for continuity with ground when you press the horn button. That wire's color code should be White with a Green Stripe (EL-208). I would try this first. Then work backward, leaving pulling the airbag and risking damage to the expensive spiral cable for a last resort.
Heath
