94Q Transmission Randomly Won't Shift Out Of 1st Gear
chefruffy
Car: 1994 Q45
I have a similar problem with my 94-Q45. The car does not move on first gear until about 2 minutes, then it drives and shifts okay afterwards. If i'm in a hurry, I'll have to move the car on 3rd gear.
goody90q45
Car: 1992 Infiniti Q45 (sold)
Have you done any service to your transmission? Is the fluid red (clean) or brown (dirty and old)? I'd recommend doing the 2 minute Transmission Self-Diagnosis outlined on page AT-41 of the FSM and see if it leads you to any bad sensors. In the FSM there's a voltmeter self-check (at the connector) for most every transmission sensor if one should come up suspect. I've also used Lucas Transmission Treatment with great success on a few of my vehicles. Clean fluid, a new filter and a quart of Lucas may bring your transmission back to life.
http://www.nicoclub.com/FSM/Q45/1994_Q45/
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
chefruffy wrote:The car does not move on first gear until about 2 minutes, then it drives and shifts okay afterwards. If i'm in a hurry, I'll have to move the car on 3rd gear.
Check your ATF level very carefully. Also, consider changing the the external ATF filter the next time you exchange the ATF. Auxiliary ATF cooler?
