94Q Thumbing Noise Front Passenger Side
rob1
Car: 1994 Q45
When going over a bumpy, poorly patched road, or potholes a thumbing noise occurs somewhere around the front passenger side wheel well. The car has 122k and original struts which are not leaking and seem fine. This noise has been the same for over a year. Does anybody have any ideas?
CrimsonQ
Car: Purple People Eater
original struts = baddont feel bad, mine were original til 155k and it rode like a tank
Q451990
I think mine were original at 11 or 12 years and 160K+ miles. Thought everything was fine until I heard a noise. My noise was from the right front as well... sort of a rattle - kind of like a receiver trailer hitch while you're towing something. Mine weren't leaking and passed the old "bounce test" - but the rear passed that test and were leaking.
You will be absolutely amazed at how much better it feels after you replace your suspension components. I bought Q1 when she was 6 years old with 88K on the odometer and had never experienced a Q with as new suspension. Even worn out Q suspension feels better than most new cars - but as new it is unreal. The difference is very noticeable...
Heath
rob1
Car: 1994 Q45
What brand of struts to you recommend? A local shop uses Monroe.
rob1
Car: 1994 Q45
Are there other componets I should consider replacing in addition to the struts?
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
Only Tokico makes Q struts, blue=stiff, black=stock. Replace the upper control arms, tension rod bushings, sway bar bushings and all rubber components in the strut assembly. Check the tie rods and lower ball joints for play and replace if necessary.
CrimsonQ
Struts, Springs (wes has a buy going still i think)zerothread?id=134432upper links, check tierods.
Ive left out alot and im sure someone will post more links
CrimsonQ
m
911/Q45 wrote:Only Tokico makes Q struts, blue=stiff, black=stock. Replace the upper control arms, tension rod bushings, sway bar bushings and all rubber components in the strut assembly. Check the <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp ... tie%20rods" onmouseover="window.status='tie rods'; return true;" onmouseout="window.status=''; return true;">tie rods</a> and <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp ... l%20joints" onmouseover="window.status='lower ball joints'; return true;" onmouseout="window.status=''; return true;">lower ball joints</a> for play and replace if necessary.
man im tired
911/Q45
1996 Porsche Turbo
I think I fixed it, what a mess!
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
FYI the Tokico Blue is also known as Tokico HP. We say "blue" because they're blue. You can find them on ebay fairly cheap and usually with free shipping. I'm not sure if we have a sponsor that sells them any cheaper.
