94Q Taping of Connectors?
rob1
Car: 1994 Q45
I got my 94Q back after having the valve cover gaskets replaced and I don't remember so many colored wires exposed going into the connectors around and above the ornamental covers(spark plug).
Did the mechanic take the grey/black electrical tape of when taking all of the connectors apart or is my memory going? (especially noticeable on about 4 or 5 connectors on the passenger side) If he did take the tape off, how important is it to re-tape?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
if you take a picture of it i can look at it and tell you whats going on....
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Maybe the adhesive was dried out and it kept unwinding and peeing him off, I've been there.
Wind some fresh tape on so it looks pretty.
DrewQ45
Why ask? If you feel tape is necessary, then tape away. Use zip-ties too.
rob1
Car: 1994 Q45
Here is a picture of the passenger side with most of the three clusters of connectors (same generaly situtation on the other side). If taping was on original assembly (to reduce heat exposure to wires or some other reason), is regular electrical tape used or special high temp tape?
Thanks for your input!
squeefoo
1999 Infiniti I30
Regular tape works fine, or you can buy colors...
elwesso
2007 BMW M Coupe
Dont worry about it, thats how mine looks and is normal.
rob1
Car: 1994 Q45
Thanks Wes, you have given me piece of mind.
