Black stallion »
https://forums.nicoclub.com/black-stallion-u47296.html
Mon Oct 09, 2006 2:45 am
Thanks to you guys I finally replaced my upper links and tension rods(parts were in my trunk for 2 years). Since I only drove the car about 1000 miles a year (maybe less) and had previously planned to sell it, this wasn't high priority until now.
I also changed tire sizes from 225/40/18 to 245/45/18. I have the factory '02 Q wheels on my Q. I changed my steering rack about 5k miles ago (warranty) just because Louisiana has such wonderful roads!
Now I want to make sure I get the max from my suspension (allignment, tire wear, ride, etc.) I had the front struts done about the same time as the rack and I'll have the stabilizer links done this week.
My issue now is do I go with stock rears or can I put a set of blues on the rear and wait for the front to wear out?
Also, what other components do you replace/upgrade to whip that rear end into shape? How do you get rid of that "squat look" that eats up the inside of your rear tires?
I apologize if this has been covered before, but I haven't found any posts with quite the same issue. Maybe someone can shed some light or point me in the right direction. Thanks again
