94Q MAF wiring harness specs??
Q45man1
Car: 2002 Q45, 1994 Q45
I just recently bought a new MAF, connector housing and crimp terminals from Joe. I went ahead and installed the MAF but when I was removing the electrical tape around the harness, lo and behold, the soldering was crappy. There was a butt spliced in one wire and the strands of wire were cut. One wire was spliced with a larger gauge wire (16AWG).
Anyway, I want to replace this harness with new wires but didn't know the actual wire type specs. I went thru the FSM and didn't see any. I've looked up the JASO standards and there are numerous insulation materials. I'm tempted to use UL1015 or UL1007 wires but I know there is a right wire specs available (voltage, current, insulation thickness, etc).
We have use both wire types in automotive application but most applied as return wires. Once identified I can readily buy the wires from Digikey, Mouser or electronics hardware stores.
Thanks!!
Q451990
Very interesting question... I have no idea, but maybe someone will know? Might be easier to find a salvage Q and chop some of it's wiring harness out vs. figuring out the specs...
Heath
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
hey Percy-I don't know the specifics. what i can say is that the MAF is not very high current. It IS however a small differential voltage type device. I'd say proper grounding/shielding of the harness is key.
