hherbson »
https://forums.nicoclub.com/hherbson-u4516.html
Wed Mar 19, 2003 6:18 pm
Hi, my 94 Q (130,000 miles) has had a noticeable loss of power. 0-60 time used to be 7.7 seconds, now it's 11.2
The midrange also feels flat, and from mucho searching it seems the knock sensors are suspect.
Tonight I gave it 2 full rail flushes (home made job using my old fuel pump). Idle is slightly smoother, although it was excellent before.
I have had the factory service manual on backorder for some time (they have to have an order of 100 before they will re-print, and they only have around 70.) IF YOU HAVE A 94 Q, please order one.
I had to "wing" the fuel pump, water pump, struts, upper links, trans flush, rail flush etc. I really hope I get the manual before something big happens.
My questions:
Where is the connector for the knock sensor harness and how do I test it? Are the two sensors fed through the same connector?
I believe Q45tech said the resistance for each sensor should be 500k +- 50. Does this still hold true at the harness connector?
Also, how do I activate the onboard diagnostic, and what is the code for "knock sensor" ?
Any help would be GREATLY appreciated.
Thanks.
