hilock8 »
https://forums.nicoclub.com/hilock8-u19454.html
Mon Sep 13, 2004 12:14 am
Did the fuel pump replacement, disonnected battery, etc. When I got everything restored and hooked the battery back up, I reprogrammed the seat memories, 1&2. They work fine, BUT when I shut the ignition off the steering wheel does not retract and move up AND the seat does not go all the way back, actually it doesn't do anything. Except it moves to whatever position when you press 1 or 2. But everything else went fine with the fuel pump replacement..Also, looking in the trunk on the drivers side next to the speaker is a module with 2 connectors going to it!!! Is that the Keyless entry module??? If it is, where can I get a remote and if I do do, How do I get it to work????
