Q45tech wrote:.....One side has to fail before the other even if it is just a 1,000 miles after all most techs just find the worst offender and replace that one. Since that is enough to bring the vehicle into PASSING.
I talked to the shop owner when I picked the car up to ask how they determined it was a bad cat. As you had said in another post Tech, they drilled a small hole in each of the rear cats and measured emissions pre-cat (drilled hole) and post-cat (at the tail pipe) looking for a reduction. The DS cat had been changed by the PO (news to me) probably about 4-5 years ago. He must have had injector 1-3-5-7 leaks. It showed a large emissions drop between the two readings. The PS cat showed a "minimal reduction number" (in his own words) and it was obvious to him that the catalyst was tapped out, probably from the couple of 2-4-6-8 injector leaks I had.
I didn't get an OEM cat for my $108 and the state's $500, but I did get a cat installed that's rated for the "reduction" needed for the nasty beast 8 cylinder gross polluting Q45. In comparison, my Q barely failed the toughest smog standards in the country on the first test but still had very low emissions which would have passed smog inspection in any other state. The new cat made it that much better (and for only $108).
